Been having problems with air getting into fuel supply. changed the fuel filter and bled the air and car started ok. next day the car will not start again. Repeated the above steps and also found the heater plugs to be no good. changed the heater plugs and car starts ok. Gave the car a good run and stopped and started several times with no problems. After returning home and leaving the car for 2 hours I tried to start the car again only to find that it wont go. I have noticed that the heater plug light does not come on when turning the ignition key
Feb 15, 2009 at 7:23 AM
