HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Vauxhall
Zafira
Engine
Symptoms
Not Running
2001 Vauxhall Zafira ignition
CLARKY67
MEMBER
2001 VAUXHALL ZAFIRA
4 CYL
FWD
MANUAL
52,000 MILES
Car starts from cold when "normal" temp reached car stalls and wont restart until cold
Wednesday, January 23rd, 2008 AT 4:12 PM
DAVE H
MECHANIC
Check/clean or replace the CKP (crankshaft position sensor).
Friday, January 30th, 2009 AT 7:45 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
My Car Wont Start, The Sterring Lock Is Stuck, Key...
I Went To Get Into My Car After Picking My Kids Up From School And The Key Wouldnt Turn, I Pulled On The Wheel As The Sterring Lock Was On...
Asked by
nikki84
1 ANSWER
2 IMAGES
2001
VAUXHALL ZAFIRA
VIDEO
Car Cranking but Not Starting? Try This
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
2001 Vauxhall Zafira Engine Won't Start
Engine Performance Problem 2001 Vauxhall Zafira Manual 64000 Miles I Have A Problem With The Car Starting First Time. It Takes A Few...
Asked by
TAT33
1 ANSWER
2001
VAUXHALL ZAFIRA
When I Try To Start My Car It Sounds As Though The Battery Is Flat Even Although Its Fully Charged
Asked by
petersweeney
1 ANSWER
2001
VAUXHALL ZAFIRA
Engine Wont Start
I Have Vauxhall Zafira And I Started The Engine, The Gear Was Neutral And I Held The Acceletor For 1 Second Accidently And Know The Engine...
Asked by
Shoaib F
1 ANSWER
1 IMAGE
2005
VAUXHALL ZAFIRA
2006 Vauxhall Zafira Zafira Egr Clean - Engine Not...
Engine Mechanical Problem 2006 Vauxhall Zafira Front Wheel Drive Manual 40000 Miles Hi, After Following Instruction On A Number Of...
Asked by
will_c
1 ANSWER
2006
VAUXHALL ZAFIRA
VIEW MORE
How to fix an engine that wont start
Crankshaft Sensor Symptoms
