Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Vauxhall
Zafira
Engine
Replace/Remove
2001 Vauxhall Zafira engine change
2001 VAUXHALL ZAFIRA
100,000 MILES • 4 CYL • FWD • MANUAL
JIM1987
MEMBER
1 POST
my engine has blown up if i change the engine or one the same will i have to change the ecu to start it thanks jim
Mar 18, 2010 at 10:25 AM
DAVE H
Experienced Mechanic
you will not need to change the ECU if you install a new/used engine from the same year and size
Mar 19, 2010 at 12:54 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
