2000 Vauxhall Zafira transponder
2000 VAUXHALL ZAFIRA
DTLM0
  • 10 POSTS
Engine Performance problem
hi i need to send my ecu away to get it checked but they need the transponder and my ignition key the transponder is by the ignition key iv'e taken the cowl of around steering colume can you tell me please how do i get the transponder off many thanks dave
Jun 28, 2010 at 10:23 AM
DAVE H
  • 13,384 POSTS
Your local library or autoparts store will be able to supply a repair manual with instructions .. you usually just remove the screw and wiring connector then remove from around the barrell ?
Jun 29, 2010 at 12:12 PM
