2000 Vauxhall Zafira engine
DAVY59
Noises problem
2000 Vauxhall Zafira 4 cyl Front Wheel Drive Manual
hi' i'm getting a rattling type noise from the bottom end of engine its at its worse when first starting up as it warms up it quietens right down to a slight tappy noise. when applying the pedal its goes louder like ollies in engine type noise the car runs and picks up fine with power but does tend to smoke especcially when applying a top up of oil until it warms up then its fine
thanks
Jan 31, 2009 at 12:17 AM
DAVE H
  • 13,383 POSTS
check the catalytic convertor fpr damge and plugging/blockages .. also you could drain engine oil and check the oil for any metal deposits
Jan 31, 2009 at 1:56 PM
