2000 Vauxhall Zafira BROKEN AIR CON PUMP
2000 VAUXHALL ZAFIRA
8,700 MILES • 4 CYL • 2WD • MANUAL
SVETRUCK
IS IT POSSIBLE TO BYPASS THE AIR CON PUMP WITH A SHORTER BELT
AS THE AIRCON PUMP BEARINGS ARE GONE AND GETS HOT SNAPPING THE DRIVE BELT
Jun 10, 2010 at 5:53 AM
DAVE H
  • 13,384 POSTS
you can bypass the A/C compressor if you find the correct size belt
Jun 12, 2010 at 8:48 PM
SVETRUCK
[quote:884e786a2e="Dave H"]you can bypass the A/C compressor if you find the correct size belt[/quote:884e786a2e]
Jun 13, 2010 at 6:16 AM
