1999 Vauxhall Zafira
MISSCBARNES
Engine Mechanical problem
1999 Vauxhall Zafira Front Wheel Drive Manual 72000 miles
my zafira has been making a grinding noise coming from the drivers side for a llittle while then yesterday while i was driving the battery light came on and then it just cut out and wouldnt start. All the lights radio wipers etc still work and on checking the battery it has 12 volts with the lights off 10 volts with them on and when you try to turn the car on the volts go down to 2, could this be the alternater or something else please help
Feb 18, 2009 at 4:18 AM
DAVE H
  • 13,383 POSTS
your alternator probably needs replacing .. you will need to get the car started (jump start) then using a voltmeter across the battery terminals .. check you are getting a charge of around 13.5 volts with engine idleing .. if you are getting less then replace the alternator !!
Feb 18, 2009 at 11:19 PM
