2005 Vauxhall Vectra display
2005 VAUXHALL VECTRA
42,375 MILES • 6 CYL • 2WD • MANUAL
GERARD OKANE
the display lights on the dash do not come on and the guages do not work , there are two lights on permantley the boot light and a door light . is this likely to be a fuse . are the two lights i described on for safety reasons .
Sep 13, 2009 at 10:17 PM
DAVE H
  • 13,384 POSTS
check the fuses and wiring also the connectors at the rear of the display it could be any of these .. or it could be the display needs replacing or it could be a bad ground/earth supply .. an autoelectrician may be your best option !
Sep 14, 2009 at 10:28 PM
