2005 Vauxhall Vectra
2005 VAUXHALL VECTRA
KHURRAM
Heater problem
2005 Vauxhall Vectra Two Wheel Drive Manual
hi there i have a problem with my vauxhall vectra cdti sri 55 reg the thermostat needle doesnt go up hardly if it does it only goes up less than a quarter how much does this cost to repair also when the engine is running ther is a strange smell coming from the car
Feb 23, 2009 at 2:25 PM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
check coolant level is not over full mark ... what kind of strange smell ? where is the smell inside or outside ?
Feb 23, 2009 at 3:50 PM
KHURRAM
[quote:b761486a13="Dave H"]check coolant level is not over full mark ... what kind of strange smell ? where is the smell inside or outside ?[/quote:b761486a13]
the coolant level is fine the smell comes and goes its on the outside cant tell where its coming from its like a burning sort of smell how much would it cost to repair the thermostat
Feb 24, 2009 at 11:34 AM
DAVE H
  • 13,384 POSTS
replaceing the thermostat takes about 20 mins and a new themostat cost's around £5 .. so it all depends on what sort of labor charge from the garage ... should be 30 mins labor (around £25) if you do take it to the garage ask them to diagnose the burning smell ..should cost nothing for a diagnosis in the hope they get the work .. a burning smell could be a drive belt getting worn could even be the clutch it is difficult to diagnose without being on scene and actually smelling it ??
Feb 24, 2009 at 11:56 AM
