2004 Vauxhall Vectra washers,heat control,a.c.control &
2004 VAUXHALL VECTRA
70,000 MILES • 4 CYL • 2WD • MANUAL
ALPHAELEC
I've checked all fuses related to these parts.I assume it may be a relay fault.It happened after I got a company to replace my alternator. but I've left it too long to return it
Jun 15, 2009 at 5:47 PM
DAVE H
  • 13,384 POSTS
could you explain the fault in more detail ... the alterantor could be faulty or the belt not tight enough !
Jun 17, 2009 at 5:18 AM
ALPHAELEC
what I said originally is that my washers,heat controls and air cond.controls have not been working since I had a garage change my alternator ..the alternator is working fine but I feel they've caused a fault in something like a relay ,because all the related fuses are intact
Jun 17, 2009 at 3:50 PM
