2004 Vauxhall Vectra performance after overheating
2004 VAUXHALL VECTRA
65,000 MILES • 4 CYL • 2WD • MANUAL
JENNYHALL1
My car is loosing power and is bad in 1st gear. Very slow coming out of junctions and horrendous on hills, needs to be reved in 1st gear to get up the hill. Usuall power was fine, never needed to rev at all.
Car over heated causing the cambelt to slip and water basically boiled my engine.
It had fitted a headgasket, 8 exhaust rockers, 2 valves, new inlet manifold, egr valve, vaccum pump, water pump and cambelt kit.
Nov 17, 2009 at 5:53 AM
DAVE H
  • 13,384 POSTS
return the vehicle to the repair center that did the work .. sounds like you have very little compression ..
Nov 22, 2009 at 9:42 PM
