for some reason my car wont go over 4000 rpm i replaced air flow mas but still same. thank you
Jan 19, 2009 at 1:04 AM
DAVE H
✓Experienced Mechanic
is the CEL (check engine light) showing on the dash ? and also was CEL the reason you changed the MAF sensor .. your car is in LIMP mode .. it will need plugging into a computer to retrieve the fault code and reset the ECU if you have repaired the fault already ..
