2003 Vauxhall Vectra hi
60,800 MILES • 4 CYL • FWD • MANUAL
VEC00
for some reason my car wont go over 4000 rpm i replaced air flow mas but still same. thank you
Jan 19, 2009 at 1:04 AM
DAVE H
  • 13,383 POSTS
is the CEL (check engine light) showing on the dash ? and also was CEL the reason you changed the MAF sensor .. your car is in LIMP mode .. it will need plugging into a computer to retrieve the fault code and reset the ECU if you have repaired the fault already ..
Jan 21, 2009 at 9:24 AM
