2002 Vauxhall Vectra TURNS OVER,WONT START
2002 VAUXHALL VECTRA
111,000 MILES • 4 CYL • 2WD • MANUAL
ZUWENA
CAR IS 2.2 SRI 150
ENGINE TURNS OVER BUT NO COMPRETION TO START ENGINE.CHECKED CAM CHAIN AND IS OK.
Feb 6, 2009 at 8:51 AM
DAVE H
  • 13,384 POSTS
check the timing marks are lined up correctly .. the chain may have jumped !! do you have no compression on any cylinder ? ..
Feb 6, 2009 at 12:30 PM
ZUWENA
Hi, i have some compretion in one cylinder,but i need to know where the timing marks should line up..thankyou for your help.
Feb 9, 2009 at 12:33 AM
DAVE H
  • 13,384 POSTS
if the cambelt is ok the timing marks should be already lined up ? have you replaced the belt ? did you check compression on all cylinders with a compression tester ?
Feb 16, 2009 at 12:37 PM
