2002 Vauxhall Vectra RPM going up and down and temperature
DENNIS LEY
Engine Performance problem
2002 Vauxhall Vectra 4 cyl Two Wheel Drive Manual
When I am stop and the engine is running the RPM and going up and down and at times the temperature relly increases.
Sep 2, 2009 at 12:58 AM
DAVE H
  • 13,383 POSTS
check for vacuum leaks and check/clean or replace the MAF (mass airflow) sensor .... check coolant level is correct !
Sep 4, 2009 at 11:46 PM
