2001 Vauxhall Vectra Z22SE intermit no power spot 2000rpm+
2001 VAUXHALL VECTRA
48,000 MILES • 4 CYL • FWD • MANUAL
GEORDIE-CHRIS
Have a 2001 2.2 SRi Petrol Vectra that intermittently will loose power above 2000rpm. No warning lights on - fault will last a couple of days then clear.
Fault Codes P1572, P0571 + P1612 stored - I belive from searching the net the 1st two are related to the brake light switch, and the third is an immobalizer intermittent fault.
Not sure if these are related to the fault - any help appreciated!
Mar 10, 2010 at 4:59 AM
DAVE H
  • 13,384 POSTS
replace the switch on the brake pedal bracket ..
Mar 11, 2010 at 9:21 PM
