2001 Vauxhall Vectra car broken down
2001 VAUXHALL VECTRA
LEOQUIGG
Car ignition turns on ok but there are no revs when accelerator is pressed down
Sep 25, 2009 at 8:04 PM
  • 31,937 POSTS
Hi there,
Check for a broken throttle cable, see if the throttle plate is moving when the pedal is pressed.
Mark (mhpautos)
Sep 25, 2009 at 9:24 PM
DAVE H
  • 13,384 POSTS
hope you don't mind me adding 2 pence worth !! if the throttle cable is good !! Have the vectra plugged into a diagnostic scanner and read and write down the fault codes ... then delete the codes to reset the PCM (cars computer) the car should rev correctly again now, but you will have to get the faults fixed that the computer is showing or this fault will re-occur ? hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_smiley3_11.png
Sep 26, 2009 at 10:04 PM
LEOQUIGG
Thanks guys for your answers. Our mechanic went to pick up the car and everything was checked as you both suggested but the car started straight away and he said he couldnt find anything wrong with it. Its going now, so far so good. The car has never let us down before. strange...!!!
Sep 28, 2009 at 2:24 AM
