1999 Vauxhall Vectra battery
1999 VAUXHALL VECTRA
100,000 MILES • 4 CYL • 2WD • MANUAL
CHRISROBSON
  • 5 POSTS
my battery drains when the cars switched off iv replaced old battery but it still happens.
Jan 7, 2010 at 3:42 AM
DAVE H
  • 13,384 POSTS
check for something staying ON while vehicle is off .. boot light/glovebox light/radio .. etc. etc .. also check battery connections are good and clean at all connector's including the earth points on chassis and engine
Jan 7, 2010 at 9:16 PM
CHRISROBSON
  • 5 POSTS
thanx iv checked that there is nothing left on and there isnt but i have noticed a snaped wire attached 2 the bodywork under the bonnet near the passenger headlight could this be the problem? regards c.robson
i cant see wer the rest ov of the wire is could u tell me were 2 locate it please i think its a 1.5mm wire and it is black thanx.
Jan 8, 2010 at 9:56 PM
DAVE H
  • 13,384 POSTS
Yes this could definately be the problem .. re-attach the wire.
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_948.png
Jan 9, 2010 at 7:29 PM
CHRISROBSON
  • 5 POSTS
thanx i will try :). i have another problem my car keeps cutting out when it should be ticking over i hav replaced the 2 sensors on the air filter as i was told this could be the problem but nothing has changed my engine management light is also on almost all the time which is affecting the power i realy appreciate your feed back. regards c robson
Jan 10, 2010 at 1:58 AM
DAVE H
  • 13,384 POSTS
You really need to have the car plugged into a diagnostic scanner to retrieve the fault codes, this will tell us where the fault lies ..it could be any number of sensors/parts causing this symptom, repost with full fault codes for further assistance and repair information !
Jan 10, 2010 at 11:02 AM
