1998 Vauxhall Vectra relay
COOLPAUL
Electrical problem
1998 Vauxhall Vectra Two Wheel Drive Manual 155983 miles
ive got a 1998 1.8 vectra i need to no where the front wind wiper relay is under the bonnet my fuse inside the car is ok my wiper switch is ok my wiper motor i had to replace but still wont work some one told me it could be the relay but dont no which one it is can you give me to which direction i should be looking at thanks
Jan 20, 2010 at 2:07 AM
DAVE H
  • 13,383 POSTS
we do not have the fuse/relay locations for this vehicle .. your local library or autoparts store will be able to supply a repair manual with the details you need
Jan 20, 2010 at 6:40 PM
MAXI_P
  • 6 POSTS
hi cool paul, try this....
in your fuse box, under dash, towards the left hand side (nearest the steering whel) there should be a brown relay...
to the right of the brown, shud be a green relay, and next to that a black relay (this should be above a blue one!) - its that black relay which is linked to your wipers. Change that and see how you get on.
Maxi
Feb 11, 2010 at 5:47 AM
