1998 Vauxhall Vectra helppppppppp
112,000 MILES • 4 CYL • 2WD • MANUAL
SWEETSPEAS
Have a 1998 vauxhall vectra 2.0 16v, has 112k miles on it.. just bought off a guy, the guy had a new head gasket put on it about 600miles back but now is losing water so he sold it for cheap to us as he couldn't be bothered with it.. What it is doing is.. when the engine gets up to temperature the water in the header starts to rise to the top causing it to escape from the cap and from the over flow.. engine temp on the car doesn't get any hotter than 90c.. coolant is not clean either but dunno if this is recent or always been like that.. coolant doesn't seem like its boiling either and all pipes around the engine do get hot, the top pipe is hotter than the bottom also.. engine oil is clean.. no mayo.. no smoke out the back either, and car drives fine.. wondered if they never fitted the head gasket properly or what... any answers??? thanks
May 8, 2008 at 4:42 AM
DAVE H
  • 13,383 POSTS
the gasket could have been fitted wrong and is blocking coolant passages ? have the coolant system pressure tested and the cylinders compression tested
Feb 26, 2009 at 1:56 PM
