1995 Vauxhall Vectra
1995 VAUXHALL VECTRA
ALISON1976
Noises problem
1995 Vauxhall Vectra Two Wheel Drive Manual
when first started if cooled down makes a popping noise for a bit, like its misfiring, until it warms up then is ok and runs perfect. wondered if anyone could tell me what it could be? thank-you.
Apr 19, 2009 at 8:54 AM
DAVE H
  • CAR REPAIR CONTRIBUTOR
  • 13,384 POSTS
add a good fuel cleaner to the tank to clean the lines and injectors .. sounds like a blocked injector or the timing is slightly out or even a sticking valve ..
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_546.png
Apr 21, 2009 at 3:25 AM
