1988 Vauxhall Vectra Lock
102,000 MILES • 4 CYL • FWD • MANUAL
MARINEWILL
The steering and ignition lock key will not turn , have spent hours trying to get it unlocked, have been told that to fit a new barrel lock I have to first get the old lock turned to the second setting and incert a wire in a small hole at the side then it will slide out, but I'm unable to get the key turned, will I have to us force ? Hope you can help,
Dec 13, 2008 at 8:59 PM
DAVE H
  • 13,383 POSTS
you will have to drill the old lock out i'm afraid if you cannot get it to turn .. try using a little WD40 down the inside of the lock barrel
Feb 16, 2009 at 12:53 PM
