2008 Vauxhall Tigra hazard lights
BADGER2606
Electrical problem
2008 Vauxhall Tigra 4 cyl Front Wheel Drive Manual
when getting in car hazard lights come on and won't switch off, the only way to stop them is to lock and unlock the car and then switch them off.
the rate of flash is faster than the hazard lights but you can start the car and drive off with them on.
It's not my car but my nieces and when she has turned up at my house beforeshe switches off the car i go out and just turn the hazards off, this time she left the car running and I couldn't switch them off.
Mar 7, 2009 at 10:24 PM
DAVE H
  • 13,383 POSTS
This sounds like an alarm system fault .. the vehicle needs to be plugged into a vauxhall diagnostic scanner to locate the fault !! bear in mind the car is still under warrenty and any work carried out by a non-vauxhall service centre would void the warrenty .. as it is under warrenty they should locate and fix this for free ..!
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_64.png
Mar 7, 2009 at 11:43 PM
