1997 Vauxhall Tigra rocker cover
IANHALL
Engine Mechanical problem
1997 Vauxhall Tigra Front Wheel Drive Manual 67000 miles
i believe the rocker cover seal is no good as it is leaking oil into the spark plugs. how do i get to this seal to change it
Dec 3, 2008 at 11:16 PM
DAVE H
  • 13,383 POSTS
remove the rocker cover .. remove the seal/gasket replace with new and re-install cover .. making sure it is seated correctly ..
Feb 15, 2009 at 10:37 PM
