cuts out when car is driven fast?
1996 VAUXHALL TIGRA
88,000 MILES • 4 CYL • 2WD • MANUAL
TAMFRNZ
Engine cuts out when driven fast and then when slowing down. Engine management light comes on and car quits it. Need some direction as to what the problem is ! apart from the issue car runs fine otherwise.
Nov 26, 2009 at 6:41 AM
SQM
  • 6,383 POSTS
Typically when a vehicle seems to hesitate on acceleration is can due to weak spark plugs or poor fuel supply.
First need to check the spark plugs. Inspect, clean and adjust the gap if necessary. If there is too much carbon build up they need to be replaced.
https://www.2carpros.com/articles/how-to-change-spark-plugs
If there is a restriction on the fuel line for the fuel pressure regulator is not functioning properly it could also make the engine to hesitate on acceleration.
Check the fuel pressure at the fuel rail. Make sure the fuel filter is clean and free of any debris.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
As you mentioned the check engine light is illuminated. Get the vehicle scanned for trouble codes. As it can help with the diagnostics.
Sep 23, 2021 at 7:44 AM
