1995 Vauxhall Tigra Timing marks
EMMA.NICHOLAS
Engine Mechanical problem
1995 Vauxhall Tigra 6 cyl Two Wheel Drive Manual
What are the timing marks?
Mar 2, 2009 at 2:51 AM
DAVE H
  • 13,383 POSTS
the tming marks are indented marks on the crankshaft and camshaft pulley's .. these have to be lined up correctly when replacing the timing belt to ensure engine runs correctly and is not damaged when cranking the engine !!
Mar 2, 2009 at 3:07 AM
EMMA.NICHOLAS
What do they correspond with? where are they? Do I need a diagram?
Mar 2, 2009 at 5:21 AM
DAVE H
  • 13,383 POSTS
There is a mark on the camshaft that lines up with a mark on the block ... there are marks on the camshaft's that line up with marks on the head !! this a very precise repair and should be carried out correctly or damage can occur to the engine !! you should really get a manual from your local library or autoparts store for PRECISE step by step instructions on this repair !!
Mar 2, 2009 at 9:16 PM
