1994 Vauxhall Tigra
1994 VAUXHALL TIGRA
66,826 MILES • 4 CYL • FWD • MANUAL
ROSEBIRD
Hi, my car won't accelerate properly. When I accelerate to pull away, there is a short time, maybe a second or two, before it moves. It makes all the right noises, but goes nowhere very fast, then after the short lag, it pulls away quickly. It's almost like it is thinking about it first. There also seems to be a problem going up hills, as the power seems to fade, as if the car is getting tired. I have changed the ignition leads, not sure what to try now. I am not very mechanically minded, you see!! Please help!
Aug 3, 2009 at 4:37 AM
DAVE H
  • 13,384 POSTS
sounds like the clutch may be slipping and needs replacing ... also replace the spark plugs and check/clean service the distributor/rotor arm !!
Aug 5, 2009 at 10:54 PM
