1998 Vauxhall Sintra oil pressure relief valve
1998 VAUXHALL SINTRA
121,000 MILES • 6 CYL • FWD • AUTOMATIC
JON780
My wife drove our car for about 400 yds with the oil light on. Local garage got the engine turning but it sounded dry inside. I suspect oil pump failure but vauxhall said to check the oil pressure relief valve first to make sure it's not stuck open.
Do you have any idea where it is located on the V6 sintra engine?
Mar 21, 2010 at 11:53 PM
The oil pressure relief valve is in the oil pump-check the oil pressure with a mechanical gauge if normal replace the oil pressure switch
Mar 22, 2010 at 12:01 AM
