1998 Vauxhall Sintra oil in radiator header tank.
TC1963
Engine Mechanical problem
1998 Vauxhall Sintra Manual
when i started driving there was a knocking/ticking noise coming from the engine (sounded like playing card in bycicle wheel). however it only knocked when the accellerator pedal was depressed. i drove like this for a few miles before there was a lack of power. the temperature started to climb then the engine died. when the bonnet was lifted there was steam coming from the header tank and it was full of oil. there is no water in the head. oil filler cap clean, no white gunk. help.
Nov 17, 2009 at 10:00 PM
DAVE H
  • 13,383 POSTS
check the water pump is working and have a compression/chemical test to check for headgasket failure
Nov 22, 2009 at 9:50 PM
