1997 Vauxhall Sintra Vauxhall sintra not sparking
1997 VAUXHALL SINTRA
IKFLETCH
Engine Mechanical problem
1997 Vauxhall Sintra 4 cyl Front Wheel Drive Manual
Hiya
I have got a Vauxhall sintra that has recently needed a ignition barrel fitting which has been done. But the car has got no spark and will not run!
Thanks Kate
Jun 5, 2010 at 10:47 PM
Turn the ignition switch on and check for power at the coil if so test the coil, distributor pick-up coil and the ignition control module if not check the ignition wire back to the ignition switch
Jun 5, 2010 at 11:15 PM
IKFLETCH
Thank you so much for your help. But the other half has realised that he has broken the ignition switch that the ignition barrel goes into.
Jun 6, 2010 at 3:46 AM
