Vauxhall vectra 1.8 16V idling problem
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the idle-control supply and operation checked, and have the intake plumbing inspected. Confirm the actual model year and engine before applying specifications.
Guidance references and applicability
Source: Original question and visible replies. Owner outcomes are attributed; other participants' experiences are not treated as this owner's repair. Next steps are editorial guidance, not a confirmed diagnosis. HELLA: Idle speed controller. General function and electrical checks; use actual vehicle specifications. https://www.hella.com/techworld/ae/technical/sensors-and-actuators/idle-speed-controller/
Discussion summary
A Vectra described as a 1.8 16-valve cut out at junctions instead of settling to idle. Replacing an idle valve and a sensor had not resolved the problem.
Reported outcome: No successful repair was reported.
The stored year is inconsistent with the vehicle description. A reply suggested intake leaks, but no test established a leak or failed component.
