Advice on faulty speed sensor
VAUXHALL
JAMES00
Hi there,
I was wondering whether you can help me, I have a faulty speed sensor on my Vauxhall Tigra, 1997, Auto, 2 door, I know its the spees sensor as it also contols the speedometer and thats not working I hardly get any movement from the car, can you help?
How much would it cost to fix?
Regards,
James00
Aug 23, 2007 at 8:30 AM
  • 75,988 POSTS
[quote:54a473bc4c="james00"]Hi there,
DIY its free-go find it at the tailshaft of the transmission-pull it out and inspect whether its worn out/not engaging properly or disconnected/loose connection.
To check it turn key On remove and spin it have someone look at the speedo should be fluctuating a bit-if so its not engaging.
Regards,
James00[/quote:54a473bc4c]
Aug 23, 2007 at 9:14 AM
