2001 Other Vauxhall Models speedo
2001 VAUXHALL
70,000 MILES • 4 CYL • 4WD • MANUAL
JIOHNNYNADEN1
hi i am looking at buying a vauxhall fronterra pertrol 2.2ltr year 2001 but i have been told the speedo can be sometimes intermitant i pressume it jumps up and down & it does not give a true reading i pressume the car would fail a mot for this reason not sure? & would it cost me a lot to sort out the problem & what do you think is wrong with it thanks ian.
Jan 13, 2009 at 2:01 AM
DAVE H
  • 13,383 POSTS
The speedometer gets it's signal from a VSS (vehicle speed sensor) it could be a fault on the sensor or wiring ... this would not affect the MOT .. vehicles are not driven during the MOT so the tester would not even know it is not working .. unless you are really unlucky .. but i must advise to have it repaired .. if it is picked up on during the test .. it will fail !!
Feb 3, 2009 at 11:05 AM
MADMICK
you could drive around with side lights on as i did its the back of the clocks thats the problem the milage keeps recording as mine did the same it all to do with the resistar and solded conections
Apr 16, 2009 at 9:11 PM
