Transmission problem
1997 Other Vauxhall Models Four Wheel Drive Manual 45000 miles
hi
stripped and replaced front wheel bearing on 4wd frontera with auto engage 4wd system , trouble is not sure what position the clutch for the 4wd should be in when i reassemble it can anyone help ,the haynes manual says the lug should line up with a mark on the clutch but when i took it apart the lug was right at the bottom of the slot whats correct??
thanks
hi
thanks
Mar 15, 2008 at 7:32 AM
