1997 Vauxhall Omega dic coil
1997 VAUXHALL OMEGA
EDWARD51
Electrical problem
1997 Vauxhall Omega 6 cyl Four Wheel Drive Automatic
i am fitting marrelli lpg :oscar_n: on my vauxhall omega v6. i have to get the rpm 12v signal wire from the dis coil there 4 wires on the dis coil what wire can it be
Jun 8, 2009 at 8:52 AM
RACEFAN966
  • 5,029 POSTS
Ok best I can find using the sister car the pontiac. I found that the pink wire labeled term b is the 12 volt source going into the module that the coils are on. Hope this helps.
Jun 10, 2009 at 3:03 AM
