1990 Vauxhall Nova starter motor not turning but battery po
1990 VAUXHALL NOVA
BOULTY
Engine Mechanical problem
1990 Vauxhall Nova 4 cyl Two Wheel Drive Manual
nova 1.4 luxe engine will not start. there is power from the battery but the starter motor not turning. noticed that when key is turned battery and ingnition light dont come on on the dash (parking does). thinking pos electrical connection?? note that car ok started then stalled (reccuring problem) then fault occured. have check all connections around starter motor.
Nov 26, 2009 at 9:55 PM
Try shorting out the starter solenoid and see what happens
Nov 26, 2009 at 9:59 PM
