2006 Vauxhall Meriva HAZARDS ON
KEVIN SAVAGE
Electrical problem
Switched on ignition this morning and the hazards started flashing and can't be turned off at switch.
I think it indicates a fuse problem
The hazards fuse is intact
Dec 26, 2009 at 8:20 PM
DAVE H
  • 13,383 POSTS
check/replace the flasher relay and check the switch is not jammed !
Dec 26, 2009 at 11:14 PM
