2004 Vauxhall Meriva starter motor
2004 VAUXHALL MERIVA
MICKBOU
Engine Mechanical problem
2004 Vauxhall Meriva 4 cyl Front Wheel Drive Manual
How do I remove the sterter motor on my 1700 deisel
Oct 21, 2010 at 7:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The starter should be fairly standard..disconnect battery, raise and support vehicle, disconnect electricals from starter, unbolt starter mounting bolts, remove starter and reverse to replace - access is a bit tight though.
Oct 21, 2010 at 10:29 AM
