2004 Vauxhall Meriva meriva
2004 VAUXHALL MERIVA
90 MILES • 4 CYL • 2WD • MANUAL
GARYLOWE
where is the crank shaft sensor only my car is jummping and then cutting out .i did read on the forum that someone had same trouble and it said it was acommon fault on this car.clean crank shaft sensor.thanks
Apr 19, 2010 at 8:03 PM
  • 31,937 POSTS
Hi there,
We don't have this car on our data base so i can't send you any pics, what i would do is get a scan done first as this will confirm if it is a crankshaft sensor causing this problem, i have left this question open so that others may also give assistance.
mark (mhpautos)
Apr 19, 2010 at 8:24 PM
