2004 Vauxhall Meriva Central locking on one door
2004 VAUXHALL MERIVA
MOLLYCAT13
Electrical problem
2004 Vauxhall Meriva Front Wheel Drive Automatic 62000 miles
I've recently bought a Vauxhall Meriva but the central locking is playing up.
The back door on the passenger side will not unlock via the central locking key fob. I have to pull up the lock from the inside. I sprayed WD40 down the lock and it worked for a day then stopped again. It seems to be out of sync with the other doors as the button pops up when I lock the car. It seems secure though as when centrally locked, the door won't open even though the button is up.
Any guidance would be much appreciated.
Thank you
Nov 12, 2009 at 6:29 AM
DAVE H
  • 13,384 POSTS
the lock motor (inside door) is worn and needs replacing !!
Nov 22, 2009 at 9:15 PM
