2003 Vauxhall Meriva
MARTIN_30
Engine Mechanical problem
2003 Vauxhall Meriva 6 cyl Wheel Drive Type unknown Manual 57000 miles
car been burning oil, possible stem seals? engine light came on, car broke down, test showed coil, misfire, and spark plug cylnder 3 broken at end, also oil at bottom of plugs, outcome was told need to replace engine?? v.concernd as onlypurchased 9 months ago. any advice pls??
Mar 20, 2008 at 10:26 AM
DAVE H
  • 13,383 POSTS
if it is actually the stem seals leaking .. then they just need replacing .. not a new engine ??
Feb 27, 2009 at 11:29 AM
