2002 Vauxhall Meriva
IANGDMN
Electrical problem
2002 Vauxhall Meriva 4 cyl Two Wheel Drive Manual
rear wiper failed,checked fuses and loose wires behind boot panel going into motor.any ideas?
Nov 28, 2009 at 1:19 AM
DAVE H
  • 13,383 POSTS
use a multimeter to check for live feed and good ground at motor electrical connector .. if you have both then the motor is bad !
Nov 29, 2009 at 11:50 AM
