2000 Vauxhall Fronterra will not idle
2000 VAUXHALL FRONTERRA
68,000 MILES • 6 CYL • 4WD • MANUAL
KATH434
Have changed 2 pre lambda sensors, eng mgt light still on and flashes periodically. Runs well when moving but stalls when crawling to junctions, do I need to get eng mgt light taken off by garage or am I missing something else?
Jan 16, 2010 at 2:40 AM
DAVE H
  • 13,384 POSTS
check for misfire on cylinders .. this will sometimes set a lambda sensor code .. repace plugs/coils .. also remove clean or replace the crankshaft position sensor !
Jan 16, 2010 at 7:12 PM
