1999 Vauxhall Fronterra
1999 VAUXHALL FRONTERRA
TEZ450
1999 Vauxhall Fronterra 4 cyl Four Wheel Drive Manual
i have a vauxhall frontera t reg 1999. i have changed the diesel pump with the same code and it still does not work. what do i need to do to repair the old one the electrice does not work with it. many thanks
Jan 28, 2010 at 2:35 AM
DAVE H
  • 13,384 POSTS
if you replaced with a used pump .. this may be faulty also .. replace with new pump .. check fuse and relay
Jan 28, 2010 at 9:17 PM
