2007 Vauxhall Corsa windscreen washer filter
15,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAIGE3
Hi the pump seems to be working, nozzles not blocked i have been told that the filter needs cleaning. When i look into the engine i can see the water bottle but i am unsure where or how to locate the filter. Can i get to it from looking down or do i need to be under the car or remove the wheel? Any help would be gratefully received.
thanks
Nov 10, 2009 at 2:01 AM
DAVE H
  • 13,383 POSTS
You need to remove the washer pump from the bottle .. the filter is behind the pump !! on the pump inlet tube !
Nov 22, 2009 at 9:05 PM
