2006 Vauxhall Corsa Brakes Make Grinding Noise
2006 VAUXHALL CORSA
JONSKI
Brakes problem
2006 Vauxhall Corsa Front Wheel Drive Manual 35000 miles
Hi There,
I have a Vauxhall 1.2 SXI 06 plate. When I start driving the car the first few times I touch the brakes it makes a grinding sound from the rear. After a few times braking the sound goes away. I initially thought it could be grit but not too sure as it goes away until I stop the car and start it again. It does not matter if the car is stoppped for a few minutes, hours or a day.
Any ideas much appreciated.
Thanks
John.
Jan 19, 2010 at 7:41 AM
DAVE H
  • 13,384 POSTS
check brake shoes/pads are good .. check wheel bearings !
Jan 20, 2010 at 6:47 PM
