2006 Vauxhall Corsa
BROKEBACK
Engine Performance problem
2006 Vauxhall Corsa Automatic 15133 miles
what is crank angle senser fault po335
Apr 10, 2009 at 3:07 AM
DAVE H
  • 13,383 POSTS
The CKP (crankshaft position) sensor is on/near the crankshaft which sends information to the ECU/PCM (cars computer) for the correct calculation of spark timing and fuel injection timing ... generally when this is faulty or dirty the vehicle will not run or will run rough (misfire) you will need to remove and clean or replace the CKP sensor .. I do not have any diagrams of this vehicle i'm afraid . your local library or autoparts store will be able to supply a repair manual ... it is a very easy unscrew clean/replace and screw back on repair !! hope this helps ..let me know
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_479.png
Apr 10, 2009 at 11:11 AM
