2005 Vauxhall Corsa Idle Issues
28,000 MILES • 4 CYL • 2WD • MANUAL
CORSA21
I have a 55reg corsa 1.2 thats beginning to struggle when idle. It ticks over at its normal 600rpm and every 30-60secs or so it'll try and cut out before returning to idle. My thought is that it could be a sensor, or fuel injection thing. If you have any suggestions or ideas of other possible causes I would be grateful.
May 11, 2009 at 9:14 PM
DAVE H
  • 13,383 POSTS
Check the IAC (idle air control) valve is working correctly and check the wiring to the valve also remove and clean the MAF (mass airflow) sensor ... add a good fuel cleaner to the tank to clean the fuel lines and injectors !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_693.png
May 13, 2009 at 11:24 PM
