2005 Vauxhall Corsa how to fix
LJ73UNIQUE
2005 Vauxhall Corsa
i am reading diagnostic code 1612.can you advise me how to fix this please?
May 5, 2010 at 8:20 AM
  • 31,937 POSTS
if the immobilizer light is flashing
that means that the chip in the key is not being recognized by the system
if you have a second key try that
you could get a new key programmed by a main dealer but that will cost you about €200
you could however buy yourself an opcom interface and reprogram your own (or a new key)if you have a laptop for about €40
as well as being able to read and clear any fault codes
look on ebay for opcom
should have also said you need the car pass (security code )costs about €25 if you don't have the car pass
4 digit code to get into programming on ecu
Mark (mhpautos)
Information taken from a Vauxhall web site,
May 5, 2010 at 11:59 AM
