2005 Vauxhall Corsa
Hello, I have got a problem with a 1ltr Vauxhall Corsa, It has no power and will lose speed and stall on a hill. There is a warning light on the dashboard that points to the catalytic converter, but II have removed this to see if it is blocked and causing the fault, but still getting no power from the engine. I had the car serviced 6 mths ago, which consisted of a sparkplug, oil and fuel filter change, so I am assuming it is not one of these. I have removed the ECR and cleaned it with carb cleaner and the car seems to have slightly more power, but this could just be my imagination. My next move will be to replace the ECR, but this is not cheap and I am hoping someone can tell me if I am going in the right direction. Thanks in advance. Russ.
Apr 12, 2010 at 6:54 AM
